Exp gdc, gtx970 power options.
Skoto88
(@skoto88)
I am  running a 1050ti with exp gdc 8 and a dell 12v 18a 220w power adapter. It work well but I'm not able to use the latest nvidia drivers. So I ordered a gigabyte gtx 970 mini. I see that the 970 has an 8pin power plug. Does that mean that I need to switch to a proper pc power supply with an 8 pin plug or can the 6pin output on the exp gdc handle it with a 6 pin to 8 pin adapter? I was using an hd7950 that has 2 6pin power plugs, using a 6pin splitter but that may be why I was getting such bad performance out of that card.
Yukikaze
(@yukikaze)
Noble Member Moderator
You can power the GTX970 via a 6-pin to 8-pin adapter. As for the HD7950, I ran one on a Dell DA-2 without issues for over a year back when I had an Expresscard eGPU.
Plastixx
(@plastixx)
The 970 has roughly the same TDP as a RX 480, which runs perfectly fine for me with a DA-2 and 6p to 8p adapter.
2011 17" HP ENVY 17t-2100 [2nd,4C,Q] + GTX 1050 Ti @ 4Gbps-mPCIe2 (EXP GDC 8.4) + Win7 [build link]
Skoto88
(@skoto88)
Thanks guys. I'll order one up. Can I expect a slight performance increase with the 970 over the 1050ti?
Yukikaze
(@yukikaze)
Compare the GTX1050Ti and the GTX970 on the graphs on this review at your relevant resolution. That should help you quantify the difference. On average it looks to be around 40-45% more powerful than the 1050Ti.
Skoto88
(@skoto88)
Thank you for the link. Any improvement would make it worthwhile as I paid about the same for the 970 as I did for the 1050ti. But I might have been pushing my i7 3520m to its limit with the 1050ti in some games.
cunning_fridge
(@cunning_fridge)
I did the exact same switch about a month ago, including powered by the DA-2 (no issues). The performance difference I'm seeing is around 25% averaged over a few new titles, worth upgrade. In hindsight I can't really see the point in buying the 1050ti if you can provide the additional pci-e power most decent cards need and the GDC (with adapter) can provide.
2011 12" HP EliteBook 2560P [2nd,2C,M] + GTX 1050 Ti @ 4Gbps-EC2 (EXP GDC 8.4) + Win10 [build link]
