EXP GDC Power Supply questions
Leto Atreides
(@leto_atreides)
I am planning on using an EXP GDC (M.2 M Key) for my eGPU setup.
From what I gathered, a PCIe slot can only supply 75w of power and you have to plug in to the supplemental power port of your graphics card if it takes more than 75w.
I have a few of questions about this and hope that someone here knows the answers:
  1. Do I need to use the supplemental power port of the graphics card if I am supplying more than enough power to the EXP GDC?  (For example a Dell DA-220, or an ATX cable) Or is it power limited to 75w draw no matter what?
  2. What about the opposite scenario?  If I am supplying more than enough power to the supplemental port do I need to supply the EXP GDC too?  Or is the supplemental port power limited to a certain draw as well?
  3. Basically I want to know if I actually need to power both externally.  If I do, can I split the Dell DA-220 and still power it off of the same power supply?
System: Hades Canyon NUC
mr.ribeiro
(@mr-ribeiro)
If is for M2 M KEY i "THINK" that this better than exp gdc:
https://egpu.io/go/jeyiexplicit
And have more ports *options* for psu.
defvs
(@defvs)
What card is it ?
If the card has a power input by itself, it WON'T work. You'll get an error in the device manager.
The GPU hasn't got a "passthrough". You will need to power both the GPU and the Beast.
I highly recommend not buying an EXP GDC Beast. It has horrible signaling issues. Buy ADT-Link Link stuff. Great quality. And you'll only need a 4 pin molex connector with it (plus gpu power)
Laptop : Mi Notebook Pro, i5-8250u undervolted + TDP unlocked, 8G RAM 256G nvme, MX150-2...
eGPU : Asus STRIX 1060-6G running over ADT R43SL (15cm) M.2 with Gen3 x4
Greetings from France !
mr.ribeiro
(@mr-ribeiro)
@defvs, M2 m key is playable on internal monitor?
defvs
(@defvs)
@P4RANOID it is if you have an nvidia dGPU. -10 fps approx; depends on the card and the cpu
Leto Atreides
(@leto_atreides)
@mr-ribeiro
I already have a EXP GDC v9.5 on the way.
@defvs
I looked at some of the ADT-Link stuff and I could not find any place where you connect a power source to it.  I also found the EXP GDC for $13 vs $50 for the R43SG  What do you mean signaling issues?  And which version of the EXP GDC has these issues? (Surely if its a known problem, newer versions would have sorted it out by now?)
defvs
(@defvs)
Posted by: Leto Atreides
All version are affected to my knowledge. Their cable is really badly made. Cannot run even gen 2 signaling without often crashing.
The one EXP GDC you're talking about is an x2 lane if you paid it for 13$. The ADT-Link (find it here, 30$-40$ depending on cable length) R43 is an x4 link. But it can do Gen 3 where the EXP GDC cannot.
Leto Atreides
(@leto_atreides)
@defvs
The link you posted for Aliexpress literally says "This cable does not support the notebook external graphics card, Please do not buy!" but then it goes on to list GFX cards in the description.  Does this just mean that it doesn't support "Expresscard"?
defvs
(@defvs)
Sellers just add this to make sure you don't return it saying it doesn't work when it really is juste your laptop not supporting eGPU.
Also I had the EXP GDC 9.5 and it really is horrible. You'll get lag frames, and you'll crash often in the most demanding games. Only solution is to get down to pcie gen 2 or even 1.
Leto Atreides
(@leto_atreides)
I canceled the EXP GDC purchase and I am looking at the R43SG/R3G instead.  I started a new topic trying to get feedback on this https://egpu.io/forums/expresscard-mpcie-m-2-adapters/adt-link-r3g/
(@nick_vasey)
Posted by: defvs
defvs, I think you're being a tad absolutist in the first three sentences of your statement (above): I - in fact - am running an EXP GDC Beast (v. 8.5c) at Gen 2 that is both stable and has zero signalling issues/crashes. There exists, of course, the off-chance I've just been lucky with my particular Beast.
defvs
(@defvs)
Posted by: Nick Vasey
Yup; the EXP GDC v8.5 is only two lanes though. It all depends on the GPU and also your Gen speed. You are getting more perf. drop at Gen 2 x2 compared to an R43 at Gen 3 x4. But let's compare the EXP GDC v9.x which is x4 lanes. Comparison is my own experience, as I've owned a v9.5 before and returned because of the insane issues it gave me.
You'll get theorically a bandwidth which is 2 times greater on the R43 (Gen 3 x4) than on the GDC9.5 (Gen 2 x4) and that's considering you'll even run at Gen 2. Don't even imagine running Gen 3 with it.
You're saying that you are not getting any crashes. Please do try to see in the Windows Event Observer, in the System category, if you get some WHEA-Logger errors. Theses are signs of corrected errors. Which are not "crashes" but often shows that your PCIe link is not stable. Windows attempts to correct the errors in PCIe, and that creates random performance drops.
(@oussama_one-gamer)
Am I need to get power supply whene the graphic card don't need it like gt 610 for work the exp gdc?
