GDC EXP BEAST 8 pin power input.
ACEnt96
(@acent96)
Hello, may i know that the 8pin power input of the GDC EXP BEAST can be plugged in directly with the power supply which have 6+2 pins? or 4+4 pins? Thanks a lot!
mr.ribeiro
(@mr-ribeiro)
Good question, i also waiting an answer.
(@daniel_hoyland)
There aren't any studies on the 2x 4pin into the GPU. Anecdotal evidence however suggests that this would be compatible. Otherwise, a 6+2pin is the same as an 8 pin.
