Extracted from this build:
The R43SG-TU version of R43SG is actually the same product as the regular version: the cable can be turned backwards after removing the tape that holds it, however this can be done only once (try again and it'll break).
Lenovo ThinkPad X220 w/ Exp GDC 8.5c via ExpressCard & M.2
Lenovo Y700-17ISK w/ ADT-Link R43SG-TU via NVMe [More Info]
EVGA GeForce GTX 970 SSC ACX 2.0+ (Part # 04G-P4-3975-KR)
PSU: Dell DA-2 D220P-01 (18A), Tyco CAD240121 (20A)
2015 17" Lenovo IdeaPad Y700 (GTX960M) [6th,4C,H] + GTX 970 @ 32Gbps-M.2 (ADT-Link R43SG) + Win10 [build link]
Hi. Nice to see the insides of it.
Any idea if this cable has the PCI-Express lanes in twisted pairs? Or it's just composed of parallel wires?
My adapter models for eGPU case projects
2013 15" HP ZBook 15 G1 (Q K1100M) [4th,4C,Q] + R7 240 @ 4Gbps-EC2 (EXP GDC 8.3A) + Win8.1 [build link]
I bought R43SG riser, NVME version, for my Lenovo y-700, I tried to test it with my old gpu and my old power supply, following the tutorial i found here.
so I removed the safety tape, and replaced it... my riser cable is only 25cm and as is tried to align my setup, i broke the pins of the cable and the nvme disk, it looks like this now...
so i broke the pins, now i need help, how do I solder it back together, is it possible? or i just lost 100$ and 2 weeks of waiting by not being careful enough.
.If skillful with soldering, you'd apply flux, align the pins and use a heatgun to reflow the solder to reattch the pins.
Otherwise just purchase an ADT-Link R43SG-TU so are not risking trying to make an R43SG into a R43SG-TU.
@nando4, hey, have you got any idea how to reattach them? i mean there are two colors of the cables inside, red ones and black ones but i don't know which one goes where on the nvme disk
