[HELP] GPU wont power on (Mini PCI-E GDC EXP Beast 8.0)
CorpseKitten
(@corpsekitten)
So I recently purchased a GTX 960 4GB and a Mini PCI-E GDC EXP Beast 8.0, I originally set this up using a cheap 220V PSU and SATA to 8-Pin adapter, the GPU would power off during heavy load due to presumably the PSU not supplying enough power to handle the dock and GPU. After rebooting when the GPU powered off for the 2nd to 3rd time, it would no longer power on again, thus I uninstalled the drivers thinking they could of potentially of been the issue and still to no avail the it wouldn't start. I have now purchased a dell DA-2 brick and a 6 pin to 8 pin adapter to go from the GDC EXP Beast to the GPU and with this new set up the GPU will still not power on, so I am wondering if I have potentially damaged the GPU or the dock, any help would be greatly appreciated!
Topic Tags
CorpseKitten
(@corpsekitten)
bump
