[HELP] PSU not powering on eGPU
ThELoser1012
(@theloser1012)
I just got a ARESGAME 500w PSU and i wanted to use it with my eGPU, I had plugged in all of the components and wires in correctly but it is not powering on the EXP GDC. Looking further into it appears to be the 20+4 pin to 8 pin connector as it was not supplying power even when i plugged my Dell DA-220 PSU into it.
If you have any info on how to fix this problem then that be greatly appreciated.
Here's an image of my eGPU setup to better understand the situation.
Topic Tags
Jinwen Kok
(@jinwen_kok)
See the yellow and black cable? it is not connected to the power supply.
