P50 and exp GDC v8.5c speed
(@dfikgjdflk)
Hello, I have this setup:
P50, R9 390, exp gdc express card v8.5c, 750w PSU, external monitor.
Made it work and games like dark souls 3 run at max settings at 1080p at 60 fps but with stuttering because it's on EC 1, x1 1.1 says gpuz.
To make it work I had to force EC speed to gen 1, instead of automatic. I also had to set graphics to discrete, as I can't turn off dgpu on p50. Doesn't work ok hybrid mode, maybe windows can only handle two different GPU makers at the same time.
I was able to expand the memory with the trick, large memory trick. What do I need to get ec3 going? Bought the exp gdc because that's all I found online. It is the version 8.5c.
(@dfikgjdflk)
I've donne some more searching and from what i gathered, because it's a socketed cable, it doesnt perform as good as if it would be soldered. With that in mind, should i try the PE4C? It's quite pricey and it almost costs me double to import to france. Does PE4C work for sure at gen3 speeds?
wimpzilla
(@wimpzilla)
Honorable Member
Egpu users should definitively drop the Express card configuration.
The pci-e speed drop is not due only to the egpu adapter cable, BUT also depending how the EC port is connected to the motherboard.
Generally the egpu cable is shielded, but OFTEN the connection between the EC part and the motherboard is ABSOLUTELY NOT.
So in general, i would wish ppl here would stop completely to advising EC card egpu setups, understanding that its is not only a egpu adapter issue, but also a EC port issue.
If you have some doubt, take a sample of 50 old laptops owning an EC port, and check for each of these 50 laptops which one have a shielded EC port/motherboard connection.
You will be surprised, the EC port was not meant to work reliably on high demanding pci-e devices.
E=Mc²
(@dfikgjdflk)
Well i saw multiple user with thinkpads P50 having gen3 speed expresscard setup so i think if it's confirmed to function it's worth using that instead of the insanely expensive TB3 enclosure (i can buy a new graphics card and a new CPU for the price of an enclosure that comes empty here in france)
wimpzilla
(@wimpzilla)
Honorable Member
Nobody said you should buy a TB3 enclosure.
The EC port in general have issues of shielding, as the egpu cable itself, that's why it is less reliable than a mini pci-e.
In your case, on the p50, the EC port is directly soldered to the motherboard, it is a new laptop so the EC connection is much better than the old ones.
It could be at this point that the cable cause the low pci-e speeds.
You should have opted for the EXP GDC M.2 version. I would have switched to a sata ssd instead of the nvme one and use the M.2 port as egpu.
It have similar gaming performances than a TB3 connection, running on a real 4x pci-e.
E=Mc²
(@dfikgjdflk)
Its because I have nvme ssd on m.2 port that I tried ec. Now I will purchase pe4c, I was partially refunded the exp GDC, I'll probably sell it on eBay
I tried.3 different GPUs, same issue only works at gen1 speeds.
jevtabg
(@jevtabg)
On Lenovo T430 EC port is solidered to motherboard, so dont see problem there.
I have Beast V8,5c and have same problem.
On Gen1 everything works fine, but on Gen2 it restarts few seconds after launching benchmark or game.
Maybe problem is that GPU cause it is using lot of power.Card is GTX 770 wind force 4 GB 256 bit and it uses 2 x 8 pins for power.
Power supply is Thermaltake 630w modular and only graphic and beast are connected.
Lenovo T430 i5,8GB,256GB ssd + 256GB msata
EXP GDC Beast V8.5c - GTX 770 4GB 256bit
Vlad_Tepes
(@vlad_tepes)
@jevtabg
Hello! I think that your problem could be 2 things, at least.
1) Power Source
2) Interference with the Express Cable. I have a t430 with gtx 1050 ti and it works great with Gen2 speed. I played 5hs without issues.
I read that the express card cable must be free, without cables over or under, because it doesn't have a good shielded cable. Try that, because i have the same laptop and works great on Gen2
rickterp
(@rickterp)
I also have the EXP GDC Beast v8.5c using ExpressCard. No issues with Gen2 speeds with my T430.
T430 x GTX 1060
Bjorg
(@bjorg)
Hello,
I am unable to find EXP GDC 8.5c (expresscard).
I search and I find mostly 8.0 and if lucky some 8.4D (which I am unsure if it will work with expresscard).
Could someone give me an exact link to a EXP GDC 8.5c Expresscard.
Thanks in advance.
@bjorg
I like this website because it has the most documentation and four different types of connectors (I don't know the version numbers of the adapters though)
https://geekworm.com/collections/exp-gdc/products/exp-gdc-pcie-pci-e-laptop-external-independent-graphics-card-adapter-docking-stations?variant=19396469391418
I have not bought anything from them.
They point to a wiki which I haven't noticed before:
http://www.raspberrypiwiki.com/index.php/EXP_GDC
And they have a pdf:
http://www.raspberrypiwiki.com/images/8/81/EXP-GDC-User-Manual-EN-20170321.pdf
