Please help (code 43) on egpu (exp gdc beast v8)
Lightmare237
(@lightmare237)
I have toshiba satellite laptop (l50-a667)
Cpu: i7-4700mq
Ram:8gb
Igpu: nvidia GT 740M
I brought gtx1080 strix as egpu and connected it from the wifi slot installed ddu and uninstalled the igpu and clean installed my new gpu but in device manager i get error (code 43) windows has stopped this device because it has reported problems . Please help what should i do now ?
GTX10xx cards used on a non-hotpluggable mPCIe interface as you are gives error 43 with NVidia drivers 372.90 or newer. The solution is to use the 372.70 driver or use a GTX9xx (or older) card instead. See https://egpu.io/forums/expresscard-mpcie-m-2-adapters/nvidia-is-killing-off-mpciengff-m2-egpus-error-43-with-372-90/
Lightmare237
(@lightmare237)
I cant change my gpu now what is the best driver version to use in this case
