[Solved] Radeon R9 380 or GTX970 for HP 8570p
Edward09
(@edward09)
Hello everyone,
I am a newbie in this forum and I've known about eGpu for just a few days. So i want to ask you some questions. I have an HP Elitebook 8570p and this is my specs :
 Intel core i5-3320m
 VGA: AMD HD 7570m
I am planning to use an EXP GDC beast 8.0 and there are 2 options i am wondering : radeon r9 380 and gtx 970. I like r9 380 more because it's cheaper, but someone says it's hard to set up an AMD card for a laptop which also have AMD dGPU . IN the other hand,a GTx is easier to set up and have better performance. SO which one should i buy ?
Another question : As I know a core I5 CPU always have integrated card Intel HD 4000 on it, but when I check in the device manager there's only dGPU Radeon 7570m. Is it possible for me to use an EGPU?
Sorry for my English . Please help me and thanks in advance
Your system has no iGPU so it nullifies NVidia's Optimus advantage. AMD has more Gen2 fault tolerance whereas NVidia will respond with "NVidia driver has stopped responding errors" if your eGPU adapter isn't Gen2 reliable. DX11 performance favors the NVidia card from my testing. You'll need to make sure there is a unified 7570M and R9 380 driver for it to work. NVidia has noticably lower power consumption, AMD has more powerful raw computing power. I found NVidia is easier to coax to work in an eGPU environment.
If it was me, I'd take the NVidia card for your system simply because of the unified driver issue. If your system only had a NVidia dGPU then conversely I'd choose AMD for the same reason.
3RYL and Edward09 liked
Sometimes mixing up brands really does help ;p.
Edward09 liked
tygpu
(@tygpu)
Hi, I asked me the same question a few weeks ago, you should have a look to R9 380X if you want an alternative to gtx970.
2012 15" Lenovo ThinkPad T530 [3rd,4C,Q] + GTX 970 @ 4Gbps-EC2 (EXP GDC 8.4) + Win10 [build link]
xarcoft
(@xarcoft)
Posted by: Edward09
Hello everyone,
 Intel core i5-3320m
 VGA: AMD HD 7570m
Did you got it working?
