very low FPS i7 2630qm+540m+gtx 1060 3gb
December 9, 2017 2:40 pm
Hi, my system is i7 2630qm+540m+8gb ram+120gb corsair ssd, laptop display 1920*1080,win.8.1 64bit. I bought msı gtx 1060 3gb. my computer does not have intel HD grafics.
I'm formatting computer. I disable "xeon(r) processore3-1200v2/3rd gen core processor PCI express root port" from the device manager, then I install 372.70. I'm testing at Furmark, it's average 37 fps on the internal display. but it is 75 fps on the external display. The internal display does not show the card on the display adapter. there is no recommended resolution. I can not test 3DMark.
How can I get higher FPS on the internal display?
What is the real problem with you?
If the problem is Intel hd graphics, How can I install Intel HD graphics?
Please help me, thank you for reply.
Please Login or Register
