HELP!! I would give a $30 or higher compensation if anyone who could help me...
Petergramaje
(@petergramaje)
Yes, you heard it right!
Specs:
  • MacBook Pro (13-inch, 2017, non-touchbar)
  • MacOs Catalina 10.15.5 Beta (19F94a)
  • EGPU: Sonnet Breakaway Box 550
  • Graphics card: Sapphire Radeon AMD RX580
  • Bootcamp: Windows 10 build 18362.295
Problem:
So, if there is anyone who could help me fix this, kindly do so! I'll be giving anyone $30 or more if anyone can help me solve this horrific problem of mine!
You can also message me on Facebook: Peter Gramaje (PH)
2017 Macbook pro 13” - Sonnet Breakaway 550 RX 580
Viktor G
(@viktor_g)
Do you use any Bluetooth devices? Mouse, keyboard etc? Disable Bluetooth on your Macbook and try again.
tsakal
(@tsakal)
@petergramaje, try to disable port 9 in device manager. it has worked with my touchbar mbp 13. I have the egpu connected on the left top port and ext ssd on the bottom left port leaving the other two empty. However, after fixing it I have successfully connected at sim racing wheel+pedals on one right usb and headphones with mic on the other without any problems
A. 2.7 GHz I7 4 Cores, 16Gb, 1TB MBP 13 2018 TB3 , EGPU Razer Core X, Nitro+ RX5700 xt 8Gb, LG 32UK550
B. 2.7 GHz I7 4 Cores, 16Gb, 1TB MBP 13 2018 TB3 , EGPU Gigabyte Gaming Box RX580 8Gb, Mac OS Catalina 10.15.2, Ext SSD Windows 10 1803
C. 3.1 GHz I7, 16Gb, 1TB MBP 13 2015 TB2 , EGPU Gigabyte Gaming Box RX580 8Gb
