Black Magic EGPU not working with Mac Pro thunderbolt 2. Help plz!
[Solved] Black Magic EGPU not working with Mac Pro thunderbolt 2. Help plz!
GSE Editor
(@gse_editor)
I can see that the Blackmagic eGPU has been recognized and upstream port connected but not downstream. As such the computer chip symbol in the top toolbar appears on plug in but when you click on it it says there is "no removable GPU". This seems like there needs to be an instruction pointing to the thunderbolt connection as a possible gpu on startup. Can someone help me with a set of terminal instructions to make this happen?
I have copied the system information displayed below so you can see the addressing problem.
Thunderbolt BusO:
Vendor Name: Blackmagic Design
  Device Name: eGPU RX580
  Vendor ID: 0x4
  Device ID: 0xA1FF
  Device Revision: 0x1
  UID: 0x0004EE21A9023900
  Route String: 1
  Firmware Version: 26.3
  Port (Upstream):
  Status: Device connected
  Link Status: 0x2
  Speed: Up to 20 Gb/s x1
  Current Link Width: 0x2
  Cable Firmware Version: 1.1.0
  Link Controller Firmware Version: 0.93.0
  Port:
  Status: No device connected
  Link Status: 0x7
  Speed: Up to 40 Gb/s x1
  Current Link Width: 0x1
@gse_editor Apple blocked non-Thunderbolt 3 Macs from using eGPU. In order to use external graphics feature with a Thunderbolt 2 machine such as your Mac Pro trashcan, you'd need a workaround. I'd recommend using Purge-Wrangler by @mac_editor.
2020 Gigabyte Z490 Vision D [10th,8C,K] + RTX 2080 Ti @ 32Gbps-TB3 (AORUS Gaming Box) + Win10 2004 [build link]
GSE Editor
(@gse_editor)
@itsage
Hi I can follow the link but an unsure on how to install this? Can you give me a step by steP?
@gse_editor
Read and follow the documentation for the script.
GSE Editor
(@gse_editor)
I was nervous to try the instructions by myself but did it late last night and it was a success. Thanks for all your help. I really did appreciate it.
Quick note:
For mac pro trash can 2013 you must have another monitor plugged in the HDMI to boot and start operation
Also you must connect via thunderbolt 2 cable and thunderbolt 3 adapter to Blackmagic AMDRaedon Pro 580 and then daisy chain to monitor, otherwise the mac will default to internal GPU rather than eGPU.
