BlackMagic eGPU Pro Samsung CRG90 Series 49 C49RG90SSN sound output problem
Scphn
(@scphn)
Connect Samsung CRG90 Series 49 C49RG90SSN to MacBook Pro 13 and 15 2018 via BlackMagic eGPU Pro with DisplayPort MacOS 10.
Have issues with no sound output on Samsung monitor.
Any idea?
Ningauble77
(@ningauble77)
@scphn
I have this same monitor in my current Radeon VII/Razer Core v2 Setup.  Are you having issues with headphones or line out?  This monitor does not have speakers.  I have had issues with audio breaking up or being distorted occasionally, to fix I either eject the egpu and plug it back in or I run Activity monitor and force quit coreaudiod.
2020 13" Razer Blade Stealth (GTX1650Ti) [11th,4C,G] + RTX 2080 @ 32Gbps-TB4 (Razer Core X Chroma) + Win10 20H2 // inc Radeon VII & 4xGPU concurrent benchmarks [build link]
Scphn
(@scphn)
Thanks a lot.
just check it is really the best Samsung monitor have no embedded speakers.
so could you advise and sound bar to this monitor? And how to connect it to monitor by wire or Bluetooth to Mac?
thanks
Ningauble77
(@ningauble77)
I don't have much experience with soundbars to use with this monitor, I always use headphones, if I ever need speaker output I just use the MacBook pro speakers.  The Monitor can output audio from the egpu via a 3.5mm headphone jack where all the cables attach.  Bluetooth would work fine too, I think the main stumbling block may be the large feet on the crg90 stand, unless you have a ton of diskspace may be tricky finding a soundbar that can fit.
