Dual Thunderbolt cable holder for MacBook Pro
gehwartzen
(@gehwartzen)
I don't think I'm going to get by with  a one cable docking solution for my 2018 MBP. Best I can see is 2 cable: eGPU + OWC Thunderbolt Dock w/ daisy chained TB3 SSD). What would be great however is a cable clip/holder with the correct spacing for the MBP ports. If not for sale maybe someone can pint me to a 3d print file?
Something simialr to this, but for newer MacBooks: https://www.thingiverse.com/thing:623748
Kelvin Tan
(@kelvin_tan)
The problem is usb-c connectors have mildly different dimensions for the connector housing, with different housing lengths. this makes it hard to create a one-size-fits-all housing.
The best way is to use something like Sugru, just mould it around with the connectors plug in, let it harden, and you have yourself a cable housing.
X1 Yoga Gen3, X1 Tablet Gen 3, MacBook Pro 15" 2018
Razer Core X / Mantiz Venus
Asrock Radeon VII, Zotac Nvidia 1080Ti Amp Core Extreme, Powercolor Vega 56 reference (flashed to V64 bios)
