EXP GDC v9.5 with two GPUs. is it possible?
Pesky Ngon
(@pesky_ngon)
Hello there.
I've heard people mention that when using the EXP GDC, you have to disable other GPUs in the system.
Is this just because laptops have in-flexible bios, or because of the product itself?
I'm not looking to use it in a laptop. I'm looking to use it in a mini ITX desktop; so that I can have my 1080ti for performance in the 16x slot, and an additional 750ti on the EXP GDC for an extra 3 monitors. But obviously I cant do that if I need to disable the 1080ti to make the 750ti work.
Any help would be very much appreciated. Thank you for reading.
Without interface details, assume you would use a M.2 slot. In which case you may encounter same issues as mPCIe/EC/M.2 eGPU users have referencing this guide to help along:
https://egpu.io/forums/expresscard-mpcie-m-2-adapters/mpcieecngff-m2-resolving-detection-bootup-and-stability-problems/
I advise against using EXP GDC for Gen3 eGPU implementations as have seen cases of reduced bandwidth.
Consider using a JHH-Link Dock or ADT-Link R43SG 4.0, both which use superior German interconnect cables stable at Gen3 and Gen4 link speeds respectively.
Pesky Ngon
(@pesky_ngon)
@nando4, ahh thats very helpful, thank you.
nando4 liked
