How far are we from GPUs with USB-C and what will be the impacts?
motoic
(@tsh3721)
I've heard that this is completely going to change things, is that true?
2018 15" MBP w/ Radeon Pro 560x
Nvidia GTX 1070
Akitio Node
32" LG 32UD99-W at 4k
macOS Mojave, Bootcamp Windows 10
2015 15" MacBook Pro (R9 M370X) [4th,4C,H] + GTX 1070 @ 16Gbps-TB2>TB3 (AKiTiO Node) + Win10 [build link]
chinsteig
(@chinsteig)
motoic
(@tsh3721)
I know that a few exist but I mean from it becoming actually common and not just on one card.
Nvidia GTX 1070
Akitio Node
OliverB
(@oliverb)
It doesn't have hardly an impact, why should it have one?
motoic
(@tsh3721)
Posted by: OliverB
I don't think this is correct. I heard rumors that it supports almost 8k, among other things. Also: power delivery.
Nvidia GTX 1070
Akitio Node
Noble Member Moderator
B Wesley
(@b_wesley)
You're wanting USB-C port for a GPU *output* to an 8K display *input* right?
Pardon the silly question, but 90% of the time when someone says "USB" and "eGPU" in the same post it means ... the other thing. The impossible thing. 🙂
Sys1: MITX Desktop in InWin Chopin
i5-4570 + 1060 6GB + PCIe 1x adapter (over USB3.0 copper)
Sys2: Dell 15 Latitude 3542
i3-4030U + 1060 6GB + mPCIe adapter for PCIe 1x (over USB3.0 copper)
Sys3:Dell 14 Inspiron E5450
i7-6500U + 1060 6GB + NGFF M.2 A/E --> mPCIe adapter
Sys4:Pending
motoic
(@tsh3721)
Posted by: Eightarmedpet
I'm still waiting for a card with TB3... 2 years now.
Any particular reason why?
I'm actually wondering how it will change affect / change eGPU boxes and what the benefits will be.
Nvidia GTX 1070
Akitio Node
Posted by: timothyov
Posted by: OliverB
8K comes from DisplayPort 1.4 with Display Stream Compression (DSC). That's not new with USB-C.
Power Delivery is part of the USB spec. The power will come from the PCIe slot or PCIe power connectors. The USB port and USB device will negotiate how much power to use so your computer won't blow up.
The graphics card has a USB 3.1 gen 2 controller. It's just another PCIe device like the audio controller that is also on the graphics card. The USB controller taking 10 Gbps from a PCIe 3.0 x16 slot (126 Gbps) is not a problem. It might have an impact in a Thunderbolt 3 enclosure (22 Gbps) but only if you're writing a lot of data to a USB-C device.
motoic
(@tsh3721)
Posted by: joevt
Posted by: OliverB
Then what's the point of cards that provide USB-C? Why are so many people saying that it's going to be revolutionary and why did the user above say he's been waiting for it for years?
Just trying to get some answers here.
Nvidia GTX 1070
Akitio Node
