hello everyone
I bought a new laptop
HP OMEN 15 dc 1000
with this config
core i7 8th gen
ram:32gb
vga:2070rtx max-q design
and I bought a aorus 1070 gaming box EGPU with 8gb capicity
I connected this vga to my laptop with thunderbolt3
and my laptop recognize that
but I get one massages about this external graphic card may perperly work good
but my nvidia control panel add this graphic card
in some moment I get a eror like cation in my device manager in front of my internal gpu(rtx 2070 max-q design)
but external graphic card works good
I need some help about how I can use both of them in the same time to have 16gb GRAPHIC ????
.Not sure that's how it should work. the GPU in your laptop will not work with the eGPU to give you 16 GBs of RAM for your graphics needs. They are meant to work standalone from each other.
MacBook Pro Touch Bar 2017 15" + Mantiz Venus MZ-02 + AMD Radeon Vega 64
2017 15" MacBook Pro (RP560) [7th,4C,H] + RX 580 @ 32Gbps-TB3 (Mantiz Venus) + Win10 [build link]
I'm quite sure that it's impossible to use both integrated and external GPU (this is the correct term, not VGA; VGA is a video connector, not a video card) for the SAME task.
Since you already have a beefy 2070 chipset, I'd suggest you just use that and return your eGPU.
2016 15" HP ZBook 15 G3 [Xeon E3-1545M, Iris Pro p580, no dGPU] + [email protected] (Aorus Gaming Box) + Win10pro
2018 15" HP ZBook 15 G5 (Q P1000) [8th,6C,H] + GTX 1070 @ 32Gbps-TB3 (AORUS Gaming Box) + Win10 [build link]
