Hello. I have a Razer Core X with the Aorus RX580 plugged to my iMac via USB-C + thunderbolt adapter. This is my usual setup.
I would like to drive an external LG Ultrafine 4K through the RX580's HDMI port, using a HDMI>USB-C cable. But the monitor is not working, even after shutting down the iMac and rebooting. Not recognized on System Report.
Is there anything I missed? egpu is recognized as usual and I've installed it last year using purge wrangler and run automate-eGPU
iMac 27-inch, Late 2012 (3,4 GHz Intel Core i7 - 32GB 1600 MHz DDR3 - NVIDIA GeForce GTX 680MX 2048 MB)
Sonnet Razer Core X + Aorus Radeon RX580 8GB
Mojave 10.14.1
Purge-Wrangler
The USB-C to HDMI cable probably only works in one direction (USB-C output of computer to HDMI input of display).
What you need is an adapter that converts HDMI to USB-C - such as the Wacom Link Plus. It also transfers a USB 2.0 signal so you can use the USB features of the display (brightness control, USB hub, etc.)
Any reason you don't use the DisplayPort output of the RX580? The Wacom Link Plus can also accept DisplayPort input.
Reading similar experiences from others I avoided DP ports cause they seem to be problematic. Anyway I bought a DP>USB-C cable that I'll try tomorrow. This is the one I'm using now that doesnt work https://uniaccessories.io/collections/cables/products/usb-c-to-hdmi-cable4k-60hz-uni-usb-type-c-to-hdmi-cable-thunderbolt-3-compatible-for-macbook-pro-2018-2017-macbook-air-ipad-pro-2018-surface-book-2-samsung-s10-and-more-gray-6ft-1-8m
Brand is the same. I was wandering if it could be some kext problem.
Mojave 10.14.1
Purge-Wrangler
I would like to recommend you to have a look at the ongoing discussion here. I believe it is going to give you the necessary approach and angles in order to reach a proper and hassle-free solution. In order to address this issue, for example, I have purchased two different equipments: Huawei VR2 cable and DeLock DisplayPort Adapter for a USB Type-C Monitor. But, I am also thinking to buy Gigabyte GC-TITAN RIDGE Thunderbolt 3 Expansion Card and a discrete GPU with Virtual Link since such equipment is going to give me more space and flexibility in future scenario so that I am not going to be limited by lack of Thunderbolt 3 support for example.
Addendum
This monitor constitutes such a unique case on its own. And that made me several times question my decision afterwards when I have decided to build a desktop PC recently. It poses so many limitations since Thunderbolt 3 is not a common "thing" yet.
.@woloban, most USB-C to DP cables only work in one direction also (like USB-C to HDMI cables). Make sure you get a bi-directional USB-C to DP cable like the one from Moshi.
https://hardforum.com/threads/use-usb-c-monitor-without-usb-c.1911817/
