Hi!
I hope "liquid cooling" is the correct English term
Well, let's get on to my question:
I want to liquid cool my Sapphire Pulse Vega 56, which is placed inside a Sonnet Breakaway 550 box. By checking the web, I already found out that there seems to be no simple plug and play solution, unfortunately. The short layout of the Pulse is of course the issue 🙁
At least there seems to be a fitting water block available:
https://de.aliexpress.com/item/32908348198.html?trace=wwwdetail2mobilesitedetail&productId=32908348198&productSubject=Bykski-Wasser-Block-verwenden-f-r-AMD-XFX-VEGA56-NANO-SAPPHIRE-PULS-Radeon-RX-Vega56-8g
As this will be my first liquid cooled setup, any hints what else I might need?
Thank you!
Macbook Pro 13" i5/16/512 - Sonnet Breakaway Box 550 with Radeon VII - Xbox One X - PS4 Pro - Nintendo Switch - Sony KD55X8505 - Denon AVR-X1300W - Klipsch - Klipsch R-115SW
iPhone 11 Pro Max 256GB Midnight Green / iPhone X 64GB Silver - iPad Pro 128GB LTE - Apple Watch Series 2 - Synology DS218+ - Xbox Live ID: Iron Breed PSN - ID: IronBreed
