Mac Pro 2013 starts and load but no video, add eGpu can help me?
Rolando Morales
(@rolando_morales)
Hello !! I got a problem with my Mac Pro 2013, two days ago I just start it and the computer makes the chime and load all the system but I don’t receive video signal. Check everything relative to adaptors and cables. Loads my Apollo Thunderbolt audio interface and I can open some audio files on my desktop, (playing with the keyboard randomly) and sounds, also open some video files but no image, nothing, even the Apple logo on startup.
Can I connect a eGpu and solve this issue? Or maybe someone had the same problem before and can help...
Thanks in advance
@rolando_morales, Unless you have screen sharing or remote desktop access, it will not be possible to enable eGPU feature. If you suspect the GPU-B card is failing, my recommendation is to take the Mac Pro apart and give it a good clean. If you don't have a rework station, you can wrap the GPU-B in foil and bake it in the oven (at 375 degrees F for 10 minutes). Let it cure for a few hours before putting the computer back together. I had early signs of failure on my own nMP and reflow the card to make it work again. I've been using an eGPU since and things are going well.
Rolando Morales
(@rolando_morales)
Hi !!! Thanks so much for your advice itsage
I recently talk to a friend for making a reflow to the cards and he is afraid to do it on Mac Pro coz never did it before (don’t know why, maybe my knowledge don’t let me see more but for me is another GPU card...maybe I’m wrong) but after reading your advice for sure I will do it...
If you have another tip for specially reflow those cards I will appreciate it
Thanks again !!
Greetings from Havana, Cuba 🇨🇺
Rolando Morales
(@rolando_morales)
@itsagelook what I finally found...The Mac Pro gives me a red led error on I/O card with the GPU2 and was a Mezzanine connector issue...
Finally and with the help of a needle and a lot of patience I can solve the problem...
Check this...
@rolando_morales, Great work spotting that tiny bent pin. The flex cables and connectors going to the bottom mainboard is fairly delicate. I'm glad you got the the root of the problem.
Rolando Morales
(@rolando_morales)
@itsage, Sorry if I didn't answer before...busy days. Well finally the MacPro starts and let me do some jobs for a while but I think I have to change the GPU's and really the option of an eGpu is interesting. I check some test in different forums and is really amazing how can the eGpu will improve the job
Thanks for everything,
kind regards
Rolando
