Macbook Pro 2016 15-Inch TB3 + Boot Camp+ Mantiz Venus + RX480 + Oculus Rift
[Solved] Macbook Pro 2016 15-Inch TB3 + Boot Camp+ Mantiz Venus + RX480 + Oculus Rift
(@alpi_mali)
Hi Everybody,
First, i want to tell you, that this Website and the community with the tutorials are great!
I solved the issue with the code12 on AMD Cards. I deactivated the left-hand thunderbolts on my Macbook pro and my Mantiz Venus eGPU on the Right-Hand side. On Boot Camp with an external SSD (inside my Mantiz), it is working well.
Now i have Problems with my Oculus Rift
During the Setup it is asking me to plug in the Sensors and the Headset. The Sensors with the USB3 are getting detected. But the problem is with the Headset. The USB and the HDMI are getting not detected.
Does anyone have the same issues?
Does anyone solved this Problem?
Is there any Workarounds, to keep my Oculus rift working?
(@alpi_mali)
Here is the solution.
Dont use the USB ports directly on the egpu. I bought an usb-c to usb-A dongle and it worked for me.
B
