Razer Core X and dedicated-CAD GPUs compatibilities
Yann Rialland
(@yann_rialland)
Hi all,
First of all, I'm newbie on this website and really happy to join the forum community !
I'm looking for a solution to improve my laptop performance on 3D modelization software (mainly use Solidworks). My models are quite heavy and it becomes really painful to make design with my current setup : DELL Latitude 7490 with i7-8650U and UHD620 chipset inside.
So I recently discovered eGPU solution. I'd buy the Razer Core X with PNY QUADRO P2200 or AMD Radeon PRO W5500 inside but I can't find any proof of the compatibility between GPUs and the Razer Core X (List of compatible graphic chipsets with Razer Core X).
I already checked the "bottleneck" between my CPU and these GPUs : it seems to be quite balanced !
Do you have any idea of the compatibily ? Otherwise, which adapted GPU (in stock) could do the same job ?
Feel free to propose, any answer is really helpful for me !
Thanks !
Mini i5
(@mini-i5)
Prominent Member
@yann_rialland, First, does the 7490’s USB-C port have the Thunderbolt symbol over it?
The W5500 is listed on Sonnet’s compatibility chart for their Breakaway Box enclosure.
nu_ninja
(@nu_ninja)
Dell has a good support article listing which systems do, don't or might have thunderbolt.
https://www.dell.com/support/kbdoc/en-us/000130984/some-systems-with-usb-type-c-port-lack-a-thunderbolt-3-controller
I would check the bios to make sure you have it.
Yann Rialland
(@yann_rialland)
@mini-i5, yes. @nu_ninja, I checked in the BIOS settings too.
  Breakaway Box could be a good solution for the AMD GPU, thank you for the proposal.
On the P2200 side, I don't find any eGPU document with certification for this board.
Is there someone who's already tried a setup with the P2200 ?
