Should I expect any issues with SAPPHIRE Radeon RX Vega 64?
Swisher Sweet
(@swisher-sweet)
I have a 2018 13" MacBook Pro and a Razer Core X Chroma eGPU and a SAPPHIRE Radeon RX 580. All is working in macOS Mojave and Windows 10 (1903) with hot plug.
However, I want to get a bit more FPS on my 3440x1440 monitor, so I'm considering replacing the RX 580 with an SAPPHIRE Radeon RX Vega 64. I prefer to go straight to the AMD Radeon RX 5700 XT, but not sure when / if this will be supported in macOS and Windows 10 via eGPU.
I assume this should be as easy as swapping out the two cards and it should just work, right?
Does anyone know if I should expect any compatibility issues with macOS or Windows?
Are there any other things I should consider before making this move?
BTW, I realize there are multiple RX Vega 64 cards out there. I assume there isn't much difference between them and I assume the SAPPHIRE Radeon RX Vega 64 is a relatively safe choice.
Thank you.
2019 16" MacBook Pro
Blackmagic eGPU Pro (Vega 56)
27" LG Ultrafine Display
2012 Mac Pro Tower
NVIDIA RTX 2070 Super
Acer Predator X34
(@louis_zhou)
Sapphire Radeon RX Vega 64 should be a very safe option as it was specifically outlined in the Apple official documentation.
Monaldinio
(@monaldinio)
It should work fine, i have the same card as an eGPU...
https://egpu.io/forums/gpu-monitor-peripherals/bootcamp-graphics-driver-problem-egpu-vega-64/
iMac 2017 27 5k | i5-7600k | 16 GB Ram | 512 GB NVMe SSD | Radeon Pro 580 | Razer Core X + Sapphire Radeon RX Vega 64 Nitro+
