Share:
Solution Aorus Gaming Box USB Ports
(@jean-mathieu_aubin)
November 2, 2018 2:02 pm
Hello !
I just found something new about this problem plagueing about every eGPU enclosure with USB ports.
I just turned off "Microsoft Device Association Root Enumator" in Device Manager under "Software Devices".
I have a Sound Card, a keyboard, a mouse, plugged into a powered usb hub (I first found this because I had problems with the USB Hub) plugged into a port of the Aorus Gaming Box 1080 with the F1.0_H2D firmeware and so far every thing is working perfectly, before I had dropoff in the sound card, key stuck pressed and mouse randomly freezing.
I hope this can help some of you ! Would like to here back from you guys if this works for others !
Have a great day !
Edit: Just so you know, you will need to turn this device on when you do a major windows update ! ie: Fall Creator Update
theitsage liked
Quote
