.My advices are
1) Stay away from BIZON.
2) Sonnet knows what they are doing.
3) Get TB3 machine.
Beyond that, answers depends on your specific needs.
What do you use the eGPU for?
How good of a GPU do you need?
Do you need eGPU on the OS X? Windows (Bootcamp)? or both?
How technically inclined are you?
Are you willing to tinker on your own, or are you looking for a supported solutions?
J
many thanks for info thats what tech guy said at BIZON - NVIDIA GTX 1080, 8 GB, DVI, 3 DP, HDMI (2560 CUDA Cores) memory - 10bps
Sonnet eGFX Breakaway Box 350W, I don't need too much power as I'm not a heavy game user, want use both for MAC OS and windows via bootcamp
I seen positive review on the company Sonnet eGFX Breakaway Box eGPU
overall package deal $795
can't be that bad, a lot people their is away around it make it work via software too etc.
sorry no expert in this
not a big fan of new macs nomore with AMD cards
in terms being technical only good mac stuff and design.........PC gaming still a beginner
.after looking at Sonnet eGFX Breakaway Box user info when it comes to FPS using T3,2, 1
not much diffrenece
T3 - 55.3FPS
T2 - 54.3FPS
T1 - 51.8FPS
