Stream/record using eGPU and one PC
Jake Choi
(@jake_choi)
I know this problem has been asked on this forum before, but none of them were conclusive/old.
What I am basically hoping to do is be able to stream/record using one PC connected to an eGPU because I currently don't have another PC I could use for a dual streaming setup.
What I was thinking of doing was having a capture card that records my eGPU output just like a dual streaming setup. But instead of feeding the output into another computer, I was thinking of feeding it back into the PC connected to the eGPU and streaming it there. I think this would work in theory, but I'm not sure if that would be too taxing on my PC in practice or if there are any limitations I'm not thinking of.
If there are any alternative solutions to streaming/recording using eGPU and one PC, I would also appreciate that too.
My specs are:
i7-8565U
16GB
eGPU GTX 750 2GB (planning to upgrade if I can get this figured out)
Have a look at the AVerMedia Live Gamer Bolt.
Jake Choi liked
Jake Choi
(@jake_choi)
@nando4, Thanks for your reply.
Is this capture card different than the other ones on the market? I've been looking at Elgato and a few other ones, but they all seemed to do similar things so I was just going to pick up the cheapest one if I can loop the output back into the PC connected to the eGPU.
