UI for Vega 64?
UI for Vega 64?
DVGamers
(@dvgamers)
May 1, 2019 6:52 pm
So, I am running a Sapphire Nitro+ Radeon RX Vega 64 in a Razer Core X, it was pretty much plug-n-play on may 2016 MacBook Pro, I did incorporate a 512 GB eSSD (Samsung Pro 970 NVME M.2) for all my gaming files. My question is, where is the UI's for the GPU? How do I mod the performance? Isn't there some kind of UI for OS X.XIV, or am I stuck with the drivers mac added for support with Mojave?
Also, is it better to run the eGPU through bootcamped Windows vs. Max OS?
My computer:
2016)15 inch Macbook Pro w/ Retina Display and Touch Bar
2.6 GHz Intel Core i7
16 GB 2133 MHz LPDDR3
Intel HD Graphics 530 1536 MB
AMD Radeon Pro 450 2 GB GDDR5
Prospective Build:
500 GB Samsung Pro 970 NVMe M.2 External SSD (Thunderbolt 3) for games only.
Razor Core X eGPU
Sapphire 11275-03-40G Radeon Nitro+ RX Vega 64 8GB HBM2
Acer 27" XFO Series gaming monitor 1920x1080 144Hz w/ AMD FreeSync Technology
theitsage
Famed Member Admin
May 7, 2019 12:55 pm
Unfortunately there's no utility like Radeon Adrenalin in macOS to fine-tune the GPU performance. You'd definitely get better gaming experience in Windows through Boot Camp.
94 external GPU build guides
stevewilliam007
(@stevewilliam007)
May 9, 2019 4:39 am
My graphics driver is updated but after the install itunes on windows 7 when I tried running the application it says minimum requirements does not meet. What is the problem behind it? Please help me to fix the problem.
