Hi all - I'm looking to purchase a Razer Core x Chroma and looking for GPU options for plug and play compatibility (similar to my 5700xt) with MacOS 10.15. Most of my use is business applications but the laptop struggles with 4K monitors and I would like to add additional screens.
Thanks for any leads.
MacBook Pro (13-inch, 2017, Four Thunderbolt 3 Ports)
Mid 2017 13" MacBook Pro - Radeon RX 5700 XT - Windows 10 1903 v1 - MacOS Catalina
MacBookPro14,2
@ra619h, If your primary needs/use is pro applications and multi screens, I'd recommend the WX series of graphics cards. The WX 4100 for example has four mini-DisplayPorts and is tiny so you can use a very small enclosure such as VisionTek mini eGFX. I have this setup and it worked great [build guide]. Buy these WX cards used through eBay for best value. WX 5100 would be really nice.
