January 20, 2021 8:21 pm
I have a Asus GeForce RTX 3090 GPU which has a triple 8 pin connector on the card. I just bought the Razer X Chroma - which only has a double 8pin connection for power...do I need a different case?
January 21, 2021 12:12 am
Howdy 😎 I also have a triple-connector 3090 and Razer Core X Chroma, and found myself in a similar situation. You have a few options:
- An 8-pin to dual 8-pin adapter, like this one: https://www.amazon.com/gp/product/B072JR4H3N . You're definitely going to experience power throttling though, so abandon all hopes of overclocking, lol.
- An external PSU that you hook up to the 3090 (and/or the other Core X Chroma power connections), although if you go this route don't forget to turn off the external PSU power supply when you turn off the Core X Chroma power switch, as the external PSU will continue powering the 3090 even with the Core X Chroma turned off, and your 3090 could overheat/become damaged.
- Replace the internal Core X Chroma PSU with something like the CORSAIR SF750. This is the route I'm taking.
2020 15" HP Spectre X360 [11th,4C,G] + RTX 3090 @ 32Gbps-TB4 (Razer Core X Chroma) + Win10 2004 [build link TBD]
