How do I build a custom eGPU and connect it to a Mid 2015 MBP
dbrian
(@dbrian)
I have some PC components that I would like to repurpose them for an eGPU setup and connect it to my 2015 Macbook Pro via the Thunderbolt 2 port.
The components I have:
- An intel CPU
- 4 x Nvidia GTX 1080 Ti
- Gigabyte GA-Z170X-UD3 motherboard
- 2 x PSUs
This is new territory for me so I am not really sure where should I start. What do I need to put build the eGPU setup?
chinsteig
(@chinsteig)
Can't use the cpu or mobo, what's the rating on psu's? I'm guessing enough to power the gpu's so the only thing you are missing is a TB2 or TB3 board. You should be able to pick up a used/new thunder2 for this.
There is a guide section as well, so you can narrow it down by your laptop and gpu to see what other components people have tried.
Mid 2017 15" MacBook Pro > ASUS XG Station Pro > RX 5700 XT > 34" 2560x1080 Ultrawide
