Hi there, I was looking to get the LG 49WL95C-W 49 Dual QHD IPS UltraWide Curved Monitor or a similar 49-inch ultrawide monitor and use it with my current laptop for just coding and productivity.
Specs:
- Processor: 2.3 GHz Quad-Core Intel Core i7
- Memory: 16 GB 1600 MHz DDR3
- Graphics: NVIDIA GeForce GT 750M 2 GB + Intel Iris Pro 1536 MB
As I enjoy coding on MacOS and feel that my machine can still function well enough, I thought I'd rather invest the money into the monitor instead of building a new machine entirely.
Currently plugging in any external monitor becomes a struggle for my laptop so I'm thinking an eGPU is the best solution.
My current things to buy are:
- Apple Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter
- Apple Thunderbolt 2 Cable
- Sonnet eGFX Breakaway Box with 650W Power Supply (to future-proof)
- AMD RX 580 8GB
Things I'm unsure about:
- Will I be able to utilise the monitor fully?
- Is future-proofing with a thunderbolt 3 eGPU chassis a good idea?
- Is this the best graphics card for my needs? (4GB vs 8GB, not using for gaming, etc)
I'd appreciate anyone's thoughts and suggestions on the best use of money for my needs, thank you!
- What do you mean? If you mean resolution, yes.
- Yes.
- It's well over spec if your only goal is driving the display.
Make note that there are some constraints to running eGPUs on Macs with discrete NVIDIA GPUs. Read the master thread in my signature for the 2014 MBP (nearly same as Late-2013) which notes the issues.
- Yes.
Thanks for the reply!
Yes I meant resolution.
Thanks for linking the thread, just got through it.
So you suggesting getting a Kepler-class NVIDIA GPU such as the NVIDIA GTX 780 for minimal issues. This should be powerful enough to drive the 42-inch display correct?
Is it recommended to get a Sonnet Breakaway Box or Razer Core X?
Note: I'm running Catalina 10.15.6
.The 49 inch display is 5120x1440.
Intel GPUs (previous to Ice Lake except Kaby Lake and Coffee Lake in macOS Big Sur) do not support width > 4096 in macOS.
Old AMD GPUs (Mac Pro 2013, or MacBook Pro 2015) will allow the 5120 width timing but will display weird pixel artifacts.
I don't recall anyone trying 5120 width timing with Nvidia Kepler or Maxwell or Pascal in macOS. I have low expectations about Kepler because it's old.
I think RX 580 is perfectly suited to solve this. Maybe RX 480 is good enough. I haven't tried that.
Is it recommended to get a Sonnet Breakaway Box or Razer Core X ?
While the 780 would have the least issues, on Catalina, DisplayPort output may not work (plus @joevt's concerns). There was some discussion about this here: https://github.com/mayankk2308/purge-wrangler/issues/48
RX 560 would work for you too (but 580 in general is much faster). If you use purge-nvda, you'll face the issues mentioned in the master thread - but you can avoid all that if you follow https://egpu.io/forums/builds/MacBook-pro-15-retina-mid-2012-razer-core-x-with-rx-580-and-functional-sleeping-waking-up-and-brightness-control/
I'd recommend the Mantiz Saturn Pro for the eGPU enclosure.
I appreciate the responses @joevt, @mac_editor!
The Mantiz Saturn Pro looks awesome. Definitely liking the extra USB ports and SSD/HDD bay.
I think I might go with the RX 560 if that's good enough. With this, how much GB of VRAM should I get if I'm not gaming?
As for the guide,
"Still some sacrifice had to be made – Nvidia dGPU is now always disabled under daily use which means there is no additional graphical power on the go." does this mean the Intel Iris Pro 1536 MB is still available?
How much of a concern is not having the additional graphics power on the go?
.I think I might go with the RX 560 if that's good enough. With this, how much GB of VRAM should I get if I'm not gaming?
Don't think that should matter - but preferably get the 4GB model.
Yes, this is a requirement for properly functional internal display.
Depends on your use-cases.
