15" MacBook Pro 2016: How to limit CPU thermal throttling when using an eGpu?
Relvce
(@relvce)
Hey!
I just wanted to know if some of you could test how bad the CPU thermal throttling in the new 15" Macbook Pros is when using an external Gpu.
Is there a way to disable the Radeon Pro Gpu inside the Gpu when you're using an eGpu or does this already happen on its own? Or is there a way to cool your Macbook so the temperatures stay low?
I want to replace my Desktop PC with my Macbook Pro and want to have the best perfomance that's possible when it's docked and connected to an eGpu.
Yukikaze
(@yukikaze)
Prominent Member Moderator
The thermal throttling when using an eGPU is less than the thermal throttling you get when not using an eGPU (because the video card under load is not located in the laptop). In other words, with an eGPU, your thermal situation is better, not worse.
Anchoricex
(@anchoricex)
Nice!
Would there be compatibility issues running a Maxwell Titan with the 2016 15" macbook pro with the radeon? I'm assuming the radeon would have to be disabled
Relvce
(@relvce)
Alright thanks!
So the dGpu inside the Macbook is just not used at all by the system and therefore doesn't produce any heat?
Relvce
(@relvce)
@ Anchoricex
I don't think that you need to disable the Radeon Gpu. As far as I understand it the system just neglects the Radeon graphics card and uses the eGpu instead for everything
