15" MBP battery swelling + egpu
Test1
(@test1)
So my macbook pro 15" touchbar late 2016 have been for a repair back in 2017 while it was still under warranty (right speaker malfuncion). They changed the whole top lid which included all I/O parts like speakers, trackpad, keyboard etc.
I ordered a new battery from iFixit to replace the current one since it has swelled to a point that it has bent the bottom panel, making it unstable if placed on flat surfaces. The lid also doesn't close properly either.
This issue began occuring since i started gaming using the egpu on bootcamp (Vega 56 + Razer Core). It's still hard to say whenever it's actually the cause for the battery problem. It's quite common for battery to swell.
I want to replace my bottom panel as well, but have a hard time finding a replacement for my macbook pro model specifically. Has anyone replaced theirs from 2016-2018? and can give me insight to if other 15" panels work with my model?
@test1, Have you contacted the local Apple Store and see what their pricing for battery replacement is? They usually replace the entire top case which includes the battery.
2019 13" MacBook Pro [8th,4C,U] + RX 5600 XT @ 32Gbps-TB3 (VisionTek mini eGFX) + macOS 11 & Win10 2004 [build link]
Test1
(@test1)
@itsage, My local authorized apple store don't provide repairs at the moment due to some weird rebranding. When I check the apple store page, they as well don't provide repairs at the moment. I have already received the replacement battery i ordered from ifixit, but haven't had time to replace it yet due to studies. It's quite a project afterall..
