2018 Mac Mini + Sonnet eGFX Breakaway box+ RX 580 crashes when connected, help!
ryanstout001
(@ryanstout001)
2018 Mac Mini i7, 32 GB, running most recent Mojave
AMD XFX RX580 with Sonnet eGFX Breakaway box 350w
Hello All,
Need some guidance, my apologies if this was posted somewhere and I missed it but I didn't see anything online that I am experiencing.
When I connect the eGPU, the icon on the top right part of the menu bar appears and I have just enough to hover over it to see it states no gpu connected, then the whole system crashes, it will power cycle and continue to crash until I power down or disconnect the eGPU.
I looked at the error log it prompted me to send to Apple and from what I can tell it appears to be a kernel panic, but that is beyond my scope of knowledge.
Things I have tried so far, I did a fresh install 3x with no different result, I have tried reseeding the GPU in the enclosure and double checked all connections, I ran connections from the same monitor to the mac mini and to the egpu at the same time.
I double checked that filevault, etc... were all off. I called Apple support since this mac mini is 1 day old and was told to contact Sonnet...
I know the card and enclosure are good because when I go into windows through bootcamp, windows 10 sees the card, even though it throws a error code 12, I tried the EFi fix I saw floating around but I must of messed it up because I couldn't boot into the new partition I created for it instead of using a usb.
I can recreate the error if someone would like to see the error log but it is very long. It does state kernel panic.
Any advice? Im kinda stuck now since I sold my custom PC to buy this setup and Im SOL without a gpu ( a better then stock gpu I mean)
2018 Mac Mini 32 GB RAm, 256 GB SSD Sonnet eGFX Breakaway Box w RX 580
Topic Tags
ggabriele3
(@ggabriele3)
did  this start happening right after the latest macOS update?
same thing happened to me last night, right after applying the update. Not only did it put me in that same crash loop, but it also corrupted the external hard disks i had connected.
I got past the crash loop by disconnecting the eGPU, booting with a monitor connected directly to the Mini, resetting SMC and resetting the NVRAM/PRAM a few times. then, once i got a full boot into macOS and things looked stable, I connected the eGPU. It worked (as a second display), so I shut down and restarted with only the eGPU connected, and it seems stable now.
I can't say which of those steps actually fixed it, but it is working now.
@ryanstout001 What's the model number of your RX 580? XFX cards tend to have compatibility issues with macOS. I recently tried an XFX RX 590 Fatboy and it caused crashing issues in macOS, same as you described. I'd recommend trying a different brand RX 580.
2018 Mac Mini [8th,4C,B] + RX Vega 56 Nano @ 32Gbps-TB3 (Gigabyte Gaming Box) + macOS 12.0 & Win11 [build link]
ryanstout001
(@ryanstout001)
@ggabriele thanks for sharing your solution, I tried, mac hung when resetting NVRAM/PRAM, I did try it after the resetting of the SMC but yielded same results as before.
@itsage thanks for the insight, I am going to try this and get the Sapphire PULSE Radeon RX 580 Graphics Card and see if that makes the difference
ggabriele3
(@ggabriele3)
So, it looks like I spoke too soon. I had booted into Boot Camp, then back into MacOS, and I had the same problem again.
All the drives are working; I'm doing some backups before trying the eGPU again, but this is very frustrating.
Georg T Jänchen
(@georg_t_janchen)
Hi there, I have a similiar issue. Though I am using a Razer Core X with the Sapphire Radeon Pulse RX 580 8GB… First everything seemed fine. I started World of Warcraft and run on mediocre settings, after 20 minutes of play the screen turned black. I switched the HDMI back to the Imac to end the game, but then the system crashed. Now I rarely get a sign of life from the eGPU and when my monitor just shows some graphic artefact stuff. This happens when I start with eGPU connected or when I attach it after launch…
Arden Lim
(@arden_lim)
@ryanstout001
@itsage
Hi, there! I had the same crashing issue with XFX RX580 black edition on my MacBook pro(with T2, running Mojave). And it turns out that there is a BIOS switch right beside the power input of this card. I just swipe the switch to the side of video output and is works!
Josh Elliff
(@josh_elliff)
I am having this exact same issue with a set up I just bought. I was worried I got gipped on a used card. I've got a brand new Macbook air 2020 (I ultimately want to use my 2015 Macbook pro but don't have a TB2 cable yet so decided it would be plug n play with the TB3 on the air). My enclosure is a Razer Core X and the card is an AMD Radeon XFX 580. When booting into the mac OS if I hot swap the device it recognizes something is plugged in, immediately says "no GPU found" and then crashes the computer. I tried running just the EGPU without the card and of course the mac recognizes it on the TB3 port with no issues or hangs/crashes. There is no way to force an update as drivers are "preloaded" into mac. On tech support with Apple (since its my wife's brand new computer, might as well start there). They tried a ton of stuff and so far have encouraged me to "upgrade" to Big Sur.
Any updates on this issue would be a huge help as I've been scouring forums for hours.
MBP Mid 2015/MB Air 2020. Razer Core X. XFX Radeon 580.
