2019 15" MacBook Pro (under macOS) + Razer Core X Chroma + USB Audio card + acti...
2019 15" MacBook Pro (under macOS) + Razer Core X Chroma + USB Audio card + active Speakers ans Subwoofer : NOISE ISSUE
Nadstaky
(@nadstaky)
Hello all,
As explained in the title, I have an USB audio card (PreSonus Studio 1810, plugged in the right MBP's side) with active subwoofer and speakers.
Since a few days, I noticed some noise when doing nothing with my MBP. Searched where it comes from : the noise is from my Subwoofer 🙁
When I play music, noise is still here.
The ONLY way to get rid of this ANNOYING noise is to plug the USB card in one USB port of the Chroma X BUT... Audio stutters when I move mouse, when I type on the keyboard (In Safari for example), or, still with Safari, when I browse web pages and so on...
SO, PLUGGING THE USB CARD IN ONE USB PORT OF THE CHROMA X IS UNUSABLE !!!
What I did :
- Changed the USB cable of the sound card : still noisy
- Plugged the USB Audio card in other Thunderbolt 3 ports : still noisy
- Changed USB adapter : still noisy
- Changed the Thunderbolt 3 cable : still noisy
- Tried with my second Razer X Chroma (for BootCamp, Nvidia card) : still noisy.
It used to work fine before (I think... ), and I'm SURE it was OK with my Razer Core X.
I need your help you gurus !
Thanks,
Eric
2019 15" MacBook Pro Radeon Pro R560X Core i9 2.3 GHz 16GB RAM
Razer Core X Chroma + AMD RX 5700 XT 50th Anniversary (macOS Catalina)
Razer Core X( v2) + Aorus RTX 2080 Ti (Windows 20 1909)
Dell UltraSharp U3818DW
Use a USB hub or dock or Thunderbolt dock?
Nadstaky
(@nadstaky)
Hello,
I forgot to mention that I did give a try with that : still noise.
As soon as I disconnect the external GPU in macOS, the noise stops...
If any of you have ideas, please let me know.
JamesDev
(@jamesdev)
Have you resolved it? I got the same issue with external DAC - Focusrite 2i2
My rigs: MacBook Pro 13" 2018 - Razer Core X + Asus STRIX 5700 XT
Nadstaky
(@nadstaky)
@jamesDev
I have resolved the issue : I have a ground switch on my SubWoofer : I removed ground and now no noise anymore
