Advice on Mac Mini Late 2012 and a Gigabyte Aorus Gaming Box with a replaced Gef...
Advice on Mac Mini Late 2012 and a Gigabyte Aorus Gaming Box with a replaced Geforce 650 GPU
Wookiestick
(@wookiestick)
I'm new to the egpu scene so please be gentle with my newbness.
Just got auros gaming box.   I have a mac mini late 2012 with Thunderbolt 1 in a dual boot setup of Mac High Sierra and Windows 10 with all the latest software updates.  I managed to get a working Geforce 650, as my Geforce 960 is too long to fit in the enclosure.  I did a crash course on egpus and saw that I needed a TB3 to TB2 adapter.   I have everything except the TB3 to TB2 cable which should be coming tomorrow.  I have the 650 in the enclosure with the 6 pin cable connected.  I am primarily wanting to get this running on Windows 10.
Wookiestick
(@wookiestick)
I have all the parts. It runs, the fans turn on. I can see a gpu and memory clock speed in the software. I can see the 750 in Device Manager.
Wookiestick
(@wookiestick)
Even though no one has responded, I'm posting anyway.  At the very least someone on an internet search may find this helpful if they're in a similar situation.  A complete clean install of both Mac OS High Sierra and Windows 10 rs3 cleared up the bulk of my problems.  It's possible the issues were tied to a a EFI/EUFI installation of Windows vs a BIOS based install.  The egpu works well with the Apple Thunderbolt driver 5.1.4.0 (02/23/2015).  Other drivers were installed with bootcamp and Snappy Driver Installer Origin.  Pretty much every game has played that I have thrown at it, including previously mentioned ones.   If the system goes to sleep, there can be issues with flickering screen after waking from that, if it even works at all.  A reboot usually fixes it though.  Just don't use sleep or hibernate features.  It also works in Mac OS High Sierra with web drivers and script.I did notice that left 4 dead 2 in Mac OS had some sporadic hitching, but that may be due to either not as efficient drivers or an issue with the game.
So a Sparkle Geforce GTX 650 1 GB will work with a Aorus Gaming box.
20180327 210927
@wookiestick , did you want to submit a build guide giving the 2012 Mac Mini + your GTX650-equipped Aorus Gaming Box?  Would just require a few pictures & some more comments. This is a low cost build, small footprint build deserving of one.
Wookiestick
(@wookiestick)
Yeah I do.  I have to gather more info from benchmarks and stuff first.
mrtang42
(@mrtang42)
Please do. I also have a mini 2012 but I have difficulty to make it work under win10. AMD rx580 card failed to lunch win10. GTX 1060 get code 12 error in driver.
Wookiestick
(@wookiestick)
https://egpu.io/forums/builds/late-2012-mac-mini-i5-aorus-gaming-box-geforce-gtx-650-tb3-to-tb1-win-10-rs3-mac-os-10-13-3/
Wookiestick
(@wookiestick)
I just snagged a 3 GB 1060 on craigslist for $140! It actually fits and works for the enclosure!  However, I am concerned that the limitations of the bandwidth of TB1 may be a bottleneck.  Could any experts chime in?  Is there going to be a performance gain?
Geforce 650 1 GB
cuda z
Geforce 1060 3 GB
cuda z 1060
Edit: I ended up putting the 1060 in my main box (i7 4790) because it benchmarked roughly %40-70 better fps than my 960 4 GB.
ICULikeMac
(@iculikemac)
Thank you for sharing all this info @wookiestick. I am so envious that you got this to work in Bootcamp! Can I ask when do you plug in the eGPU in the boot sequence etc? Windows dots? I must be doing something wrong! I've got the UEFI Win 10 now, not legacy so on the right track!
2019 13" MacBook Pro (i7 & 16GB RAM) - MacOS + Win10
Late 2012 Mac Mini - MacOS + Win10
Asus XG Station Pro (RX570 8GB + RTX 2080)
Wookiestick
(@wookiestick)
Once everything is golden, I leave it plugged in 24/7.  If for some odd reason I do have to unplug it, I sometimes have to boot to Mac OS first with it plugged it, and then reboot into Windows for it to "wake up".  Just make sure not to use Mac OS 10.13.4 unless you're prepared for murky waters as egpu support is really spotty atm (I'm on 10.13.3).
ICULikeMac
(@iculikemac)
I actually got it working first on .4 with fr34k’s script! Worked a charm, so easy. You should have no worries now.
 I cannot believe it, I’m not sure if it was your Snappy Drivers or integrated.bat with EFI that worked but it’s now working and I plan to do the same as you with it plugged in 24/7.
Thanks for getting back to me and also for doing the write up & info!
Wookiestick
(@wookiestick)
What card are you using?  I'd be interested in any insight and tips on your using 10.13.4 and fr34k's script.  I think I read that it won't work on top of the old 10.13.x script (which is what I have)
ICULikeMac
(@iculikemac)
@wookiestick Sorry about the delayed response, it was a long day yesterday.
I'm using a 1070 at the moment, the good news is there are really no tips to give, it really was just plug and play for the mini. Only thing I would mention if it doesn't instantly appear through the eGPU DisplayPort, then log out (You'll have to use HDMI on the mini) and will work after - then log in on the eGPU.
Re the older script, as far as I'm aware that was only relevant to temporary solutions on 10.13.4 not the 10.13.3 solution. I didn't uninstall anything anyway and didn't have a problem.
