Hello i'm a newbie here.Â
I just bought the Razer Core X + AMD Radeon RX 5700 XT for my mid-2015 macbook pro (10.15.1 Catalina). Installed purge-wrangler script v6.2.0 so that I can use my tb2 port.
It works perfectly with Final Cut Pro X. However, I tried several times and cannot launch DaVinci Resolve 15 studio. Downloaded 16 free version and successfully launched. However, when I imported BRaw files, there are problems in playback. There are vertical lines in the playback and some serious color cast issue. I attached a video clip and screenshot here for your reference.
https://drive.google.com/drive/folders/1B4icCgdTSRyNs2qqIbQ8n9fNhajm8830?usp=sharing
Do you guys have similar problems? Any advice?
Thanks a bunch!!! Appreciate it!
tommy
Â
15" macbook pro (mid-2015) / Razer Core X / AMD Radeon RX 5700 XT
