CUDA engine
Marcos Vinals Bassols
(@marcos_vinals_bassols)
Hello there, I’m new here and I appreciate it a lot. I am a designer using renderers like Twinmotion and Vray.  This is my current build :
MacBook Pro 15’’ mid 2015
Mojave 10.14.6
Razer Core X
Sapphire Radeon RX 580 8 GB
T3->T2
Purge-wrangler
Twinmotion is working fine with my build but Vray doesn’t because it works only with nvidia : « NVIDIA – The CUDA engine is supported only in 64-bit builds of V-Ray for Maxwell-, Pascal-, Turing- or Volta-based NVIDIA cards »
My questions :
  • will my Vray work if I replace the RX 580 with a NVIDIA ?
  • Do all the NVIDIA cards run CUDA?
  • Do I need a NVIDIA web driver?
Thank you for your insights.
