eGPU Not Detected If Monitor is already plugged in?
Sean Bugeja
(@sean_bugeja)
I've been looking around for anything about this problem, at first I thought the whole thing was a bust, so I guess I'm happy that I found out it just needs a small workaround (currently I have to manually plug the monitor everytime I plug in the eGPU, uncomfortable, but bearable.)
So I guess i'm just asking if anyone has had the same experience and if so have they figured out a way to fix it?
My setup
2017 Macbook pro
650W eGFX Breakaway Box
Vega 64 LC
Connected to
32" BenQ BL3201PT UHD Monitor
through the Vega's Display Port to get a 4K60Hz transmission.
Jyin
 Jyin
(@jyin)
I have similar setup, and mine doesn’t require reconnecting monitors
2017 iMac 5k
Sonnet BB550
Vega FE/LC
LG 27ud68 x3
Mine handles hot connect/disconnect while i have one one all three monitors connects.
It does cold boot as well as restart just fine as well.
I don’t sleep my Mac, so I can’t comment on that.
Have you tried different monitor?
J
2017 27" iMac 5K (RP580) [7th,4C,K] + RTX 2080 Ti @ 32Gbps-TB3 (Sonnet Breakaway 550) + Win10 [build link]
davidliu9518
(@davidliu9518)
Hi, I’ve got the same issue.
My setup is
Vega FE LC
Razer Core X
Dell S2817Q 4K monitor.
I have tested it with Lenovo Yoga 920, MacBook Pro 15 2017 and Dell Precision 7710. Need to unplug the monitor first before connecting thunderbolt 3.
