Fan not working
WillMorrison
(@willmorrison)
Hey all. I have an AMD RX 580 in a razer core x connected to my macbook pro with touchbar. The fans on the GPU never go on. The razer core fans turn on when plugged in but the 580's never turn on. Any solutions?
esatamacmodular
(@esatamacmodular)
i have done some basic testing with my node lite eGPU and haven't seen the fans come on except for the initial plug in of the TB3 cable. I always assumed it was because temps were so low. You could find a program where you can set fan curves and see if they come on when setting a low threshold. In any case, monitor your temps and if they pass 85C on the eGPU then I would not run for sustained periods.
xplisite
(@xplisite)
Hi all you can see this topic  https://egpu.io/forums/mac-setup/no-fans-running-in-macos/#post-43064
Mid 2017 15" Macbook Pro RP560 | MacOS Mojave | Windows 10 Pro
Sonnet Breakaway Box 350 (Change PSU for Corsair HX850)
Custom WaterCooling ASUS Vega 64 Strix | EKWB Vega Strix waterblock and EKWB Combo Radiator/Pump
