FCPX crash when exporting files other than a Pro Res master when using EGPU, Mac...
FCPX crash when exporting files other than a Pro Res master when using EGPU, Mac mini ( same for Compressor )
(@james_kilpatrick)
 Thanks for the add!
Mac mini (2018) 3 GHz 6-Core Intel Core i5 36 GB 2667 MHz DDR4
RX580 in a Razer T3 EGPU case
Big Sur, although the problem has been across a few OS before as well.... although not as bad.
FCPX works well, renders with the EGPU well, exports masters well.
Export via compressor or any form of compressed file from FCPX will hang with the EGPU until you force quit.
Once the compressed export is attempted via FCPX or Compressor its always a restart.. machine becomes a dog... does everything else perfectly all the time
No crash reports are generated ( I've seen this on a few forums with no answers as to why )
Only suggestion I have seen is that the 2 drivers ( The internal and external graphics cards ) will bring the machine down if they both try and do the same thing..?
Topic Tags
