Fortnite not using Blackmagic eGPU for internal display with the set-eGPU.io scr...
Fortnite not using Blackmagic eGPU for internal display with the set-eGPU.io script
aging_product
(@aging_product)
Hi, I'm a newbie to the forum. I am running a MBP2018 13 inch with Blackmagic eGpu. I have run the ./set-eGPU.sh script and selected option 1. When I run Fortnite without a monitor attached, it defaults to running on the internal graphics card. Is there something I am missing? All help welcome.
Gray Bush
(@gray-bush)
I'm in the same boat. I've tried using a FIT headless GS to mirror a display and the performance has improved to around 50fps but the input lag is very bad because of it. I feel like the issue is the set-eGpu command accelerates the epic games launcher but not Fortnite itself for some reason. The same problem exists for steam driven games.
