Help! MacBook Pro late 2013 15", Akitio Node, GTX980 Ti not booting
benslocum
(@benslocum)
 I was able to get a hold of a node, and installed the card, hooked up the 6+2 PCI express power from the Node PSU to the video card. I took a thunderbolt 3 to thunderbolt 2 adapter and ran a thunderbolt 2 cable from the back of the node to my MacBook Pro.  And a display port cable from the GTX card out to an external display. I turn on the power to the node, and it waited patiently for a computer to tell it to do something. I turned on my MacBook Pro and the graphics card came to life but the internal screen on the laptop has remained black. The computer is on, I can hear the fans, but nothing is being displayed. I know I need to run the automate egpu script before anything will be sent through the thunderbolt cable, through the Node, through the graphics card to my external display, but if I can't see anything or do anything on the computer, I can't run the script. Was there something I was supposed to do to prepare the computer beforehand? Akitio told me that the node that they sent me had the latest firmware.  What am I missing?!
benslocum
(@benslocum)
I'm on OS X 10.11.6 in case that helps!
Screenshot at Mar 03 13 59 14
benslocum
(@benslocum)
Not sure if this is related, but I only had one 6+2 power cable plugged in.  Should I have the other 6 plugged in too?
Screenshot at Mar 03 14 25 28
enjoy
(@enjoy)
Yes of course :))))))
Please follow this setup video skip to (10:26) because you have the new firmware.
Open Terminal and type the following commands to download and execute the script:
[Please login to see this]
2012 13" MacBook Air [3rd,2C,U] + GTX 1060 @ 10Gbps-TB1 (AKiTiO Thunder2) + macOS 10.12 // external HDD Windows [build link]
benslocum
(@benslocum)
Ok, I deserved the ridicule on the power issue Smile But there is still a problem. I have to disconnect the Node to get the computer to boot (even in recovery mode) I disabled csrutil as your video instructed. Then I rebooted and ran the script (Node still disconnected). The script told me to hot plug and run again. I did that, it downloaded the driver and told me to reboot. (Node still connected). The computer would not boot up. I held down power to to shut it off, disconnected the Node and then it booted right up when I pressed power. Shut down, plug in node, power on... no apple on the screen, no starting up. Booting up with it disconnected and then connecting it doesn't work either.
I think the boot hang you're experiencing has to do with the external monitor being connected at boot. Here are the steps you can try:
1. Boot your MBP without the Node. Run the script again and hot plug the Node when it asks you to. Make sure there's no cable connected to the GPU ports.
2. Restart after the script installation with the Node attached (no monitor).
It may take longer to boot than normal but should work. Let us know how this goes.
benslocum
(@benslocum)
@itsage Thank you for jumping in!  Sadly, that didn't work.  I did exactly as you said, and waited over 6 minutes for it to boot before hard powering off, disconnecting the Node and booting up again to write this reply.
Before I saw your message I was writing the message below.  Maybe there's something useful in there?
With the Node disconnected I can boot up the computer and everything runs fine.  If I connect the Node and run the script I get this output:
***      automate-eGPU.sh v1.0.0      ***
* (c) 2016, 2017 by Goalque & FricoRico *
Detected eGPU
 GM200 [GeForce GTX 980 Ti]
Current OS X
 10.11.6 15G1217
Previous OS X
 10.11.6 15G31
Latest installed Nvidia web driver
 Version: 346.03.15f06
 Source: 3rd Party
 Install Date: 3/3/17, 3:15 PM
Checking IOPCITunnelCompatible keys...
Searching for matching driver...
Your system is eGPU enabled and Nvidia web driver is up to date.
Bens-MacBook-Pro:Desktop benslocum$
Then I try to go to About this Mac to see what the Thunderbolt tree shows.  About this Mac does not open.  Going to Applications>Utilities>System Information does not load either.
So I tell the computer to restart.  It turns off, but does not boot back up (Node still connected). The fans run, but it never shows anything on the internal display.  I let it sit for about 10 minutes and there was no change.  I press and hold power to turn it off.
I unplugged the Node, hit power again and the computer boots right up.  Going to About this Mac and System Information work just fine.
With System information still open, I plug in the Node.  Nothing new shows up in the Thunderbolt Device Tree.
Screenshot at Mar 03 17 43 00
Then I close System Information and open it again (I still have About this Mac open so I just clicked "System Report..." again.  Now it shows this.
Screenshot at Mar 03 17 44 46
Restart again, and it won't boot.  Wait for several minutes and hard power down... then cry a little.
One more thing to try. Completely uninstall the automate-eGPU script and Nvidia Web drivers.
Then redo the script installation from the beginning with no external monitor attached.
benslocum
(@benslocum)
I uninstalled the script and the web drivers.  Then restarted.  Then downloaded and installed the script again.
Bens-MacBook-Pro:Desktop benslocum$ curl -o ~/Desktop/automate-eGPU.sh https://raw.githubusercontent.com/goalque/automate-eGPU/master/automate-eGPU.sh
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 36299  100 36299    0     0  41062      0 --:--:-- --:--:-- --:--:-- 41062
Bens-MacBook-Pro:Desktop benslocum$ chmod +x ~/Desktop/automate-eGPU.sh
Bens-MacBook-Pro:Desktop benslocum$ cd ~/Desktop
Bens-MacBook-Pro:Desktop benslocum$ sudo ./automate-eGPU.sh
Password:
Hot-plug the Thunderbolt cable and run the script again.
Detected eGPU
Current OS X
 10.11.6 15G1217
Previous OS X
 10.11.6 15G31
 Source: 3rd Party
You are running official Nvidia driver.
Driver [346.03.15f06] found from:
https://images.nvidia.com/mac/pkg/346/WebDriver-346.03.15f06.pkg
Do you want to download this driver (y/n)?
y
100 70.8M  100 70.8M    0     0  4991k      0  0:00:14  0:00:14 --:--:-- 5701k
Driver downloaded.
Removing validation checks...
Modified package ready. Do you want to install (y/n)?
y
installer: Package name is NVIDIA Web Driver 346.03.15f06
installer: Upgrading at base path /
installer: The upgrade was successful.
installer: The install requires restarting now.
IOPCITunnelCompatible mods done.
Board-id added.
Rebuilding caches...
All ready. Please restart the Mac.
Then I restarted.  Well... tried to restart.  I gave it 10 minutes of running the fans and not booting before turning it off.  Then left the node connected and tried to boot again.  Same thing... 10 minute later I turned it off, disconnected the node, booted up and wrote this reply 🙁 Do I need to update my OS?  Something else?!
Sorry to hear man. I haven't tried v1.0.0 of the script with older Mac OS version to comment. Do you need 10.11 El Capitan?
