[HELP] System slow down when eGPU accelerating
XPi
 XPi
(@xpi)
Set-up:
- MacBook Pro (15-inch, 2017)
- 2,9 GHz Intel Core i7
- 16 GB 2133 MHz LPDDR3
- macOS High Sierra 10.13.6
- Razer Core X with NVIDIA GeForce GTX 1070 8191 MB
eGPU config using learex/macOS-eGPU and external display plugged into the eGPU
Apps acceleration performing well (tested with Valley Benchmark and GeekBench4) but, when system switch to eGPU usage lag appear on macOS UI (mouse, dock, mission control, workspaces manage, ...) and not accelerated apps (firefox for example). Also, internal display goes black.
Following instructions to solve other similar topic I decided to switch off  "Displays have separate spaces", which had no improvement.
Thanks in advance!
MacBook Pro (15-inch, 2017) / macOS 10.13.6 / Razer Core X / NVIDIA GeForce GTX 1070
See hardware chart in my sig or follow instructions in automate-eGPU EFI main post for NVIDIA eGPUs + AMD dGPUs.
XPi
 XPi
(@xpi)
I've "solved" it with a very piggy method.
Using DisableMonitor to disable the built-in display.
I would like to have a better solution.
Thanks also!
