Hallo everyone,
I bought a eGpu (AKiTiON TB2) with Nvidia GeForce 1050 Ti for my iMac Late 2015 21,5-Inch. I didn't have any problems with the launch my Setups on Windows 10, but.……
when I started trying to make my video card work with macOS (10.12.6), it took me more than 4 hours, and I didn't succeed.
This is where my story begins……
I did everything step by step as in this guide:
https://github.com/marnovo/macOS-eGPU-CUDA-guide
The only thing that has changed is that the second monitor that is connected to the graphics card has started working, but if you try to check the GPU history through the system monitoring, you can see that the second graphics card is not working.
So I have no idea why it doesn’t work
That's why I'm asking for your help
I hope that you will find time for me and help me connect the video card to my iMac
