Hey All,
I recently set-up an eGPU for use with Video/Motion Graphics work and have managed to work through most of my issues (thanks to all you beautiful people), but the one thing I'm still stuck on is that when I'm using Adobe Premiere or After Effects I get choppy audio playback on the Scarlett box I usually use for monitoring sound.
The only workaround I've found is to plug a different set of headphones into my monitor and run it through that, but it's not ideal, so wondering what people think. There's no audio lag otherwise off of Spotify for example while I'm running the display off the eGPU, but in the Adobe suite it drops out every few seconds. Any help would be much appreciated!
Best,
Matt
Late Mac Pro 2013
3.5 GHZ - 6-Core Intel Xeon E5
64 GB 1866 MHz DDr3
Razer Core X Enclosure
AMD Radeon Pro W5700
Mac OS 10.15.5
Issue Persists in Adobe Suite 2020 and 2019 versions when running audio through:
Scarlett 2i2 USB
.have you solved the problem of starting mac pro 2013? because i have the same setup, it doesn't start with the egpu plugging in.
2013 Mac Pro (FP D500 x2) - Radeon Pro w5700 - Razer Core X + macOS 11.1
