Late 2015 iMac, Catalina problems with eGPU GTX 1070 Ti
Tanker-AFK
(@tanker-afk)
I am using late 2015 iMac with a Retina, 4 GHz Quad-Core Intel Core i7, 32 GB DDR3 RAM, Graphics - AMD Radeon R9 M395X 4 GB.
The eGPU enclosure is ASUS XG Station + MSI GeForce GTX 1070 Ti Duke 8 GB.
I have purchased Thunderbolt 2 cable, adapter Thunderbolt 3 to Thunderbolt 2.
Used purge-wrangler's script. Disabled SIP. While installing the script, it got stuck where it says "patching Nvidia eGPUs....". Please note that the Thunderbolt cable was plugged in. Waited for half an hour and then restarted the iMac. Used the script, but this time did not plug the Thunderbolt cable and followed the steps, chose NVIDIA, but did not install the drivers, rebooted and installed NVIDIA latest drivers.
My problem is
- I do not see the eGPU icon in the menu.
- In system information: Thunderbolt sees the ASUSTek XG Station Pro, speed up to 20 Gb/s
                                     Graphics/Displays is sees two 1. AMD Radeon R9 m395x and 2. GTX 1070 Ti.
I do not know what to do next. Does anyone have any idea how get this set-up work? I do not use Bootcamp.
Any help would be greatly appreciated and be donated using paypal.
Thanks you,
Tanker-AFK
Flint Ironstag
(@flint-ironstag)
I haven’t tinkered with eGPU in a while (only use supported configurations or known stable hacks), but I’m pretty sure the 1070 Ti is your problem. No Pascal drivers for MacOS.
MP 6,1 | 4c | d700
MP 6,1 | 6c | d500
Tanker-AFK
(@tanker-afk)
Posted by: @flint-ironstag
Thank you very much for your the help, flint-ironstag. I completely forgot to update the os to High Sierra, I automatically upgraded to Catalina, when I saw it was possible. I will try with High Sierra, if that does not help then Good Buy Gtx 1070 Ti.
Flint Ironstag
(@flint-ironstag)
You’re welcome, but the Pascal series forward are unsupported.  There are no Pascal (GTX 1070, 1080, etc) drivers for MacOS.
MP 6,1 | 4c | d700
MP 6,1 | 6c | d500
@flint-ironstag, there are Pascal drivers for High Sierra (Nvidia web drivers and Cuda) which is why @Tanker-AFK is going back to High Sierra. Question then is, does eGPU work with High Sierra. I think so?
Posted by: @joevt
Yes - should work fine.
Flint Ironstag
(@flint-ironstag)
@joevt, Wow, I had completely forgotten about that!  Sorry OP, listen to the professionals!
MP 6,1 | 4c | d700
MP 6,1 | 6c | d500
Tanker-AFK
(@tanker-afk)
Dear flint-ironstag, mac_editor and joevt,
Thank you very much for your help!
I will try this evening and update accordingly.
Sincerely,
Tanker-AFK
Tanker-AFK
(@tanker-afk)
I was able to downgrade the os to High Sierra.
Used purge-wrangler’s script. The system info showed both cards and metal support. Enclosure was also recognized. In the Activity monitor - GPU history showed both cards. When I tried to use an app to test, I saw it was only using the iMac’s GPU, there was some jerking on GTX 1070 Ti history monitoring, but not significant. Then I used set-eGPU script. First chose to use eGPU for all apps, nothing changed, then tried to use it for specified apps only. Still no success.
