Low Performance with MacbookPro + Akitio Node Pro + RX590
lucaro2708
(@lucaro2708)
Hi!
Three months ago I bought a MacBook Pro (i7-9750H), an Akitio Node Pro and a RX590. Since I upgraded to Catalina (I guess, since I didn't have it this issue before) I've had far worse performance regarding fps in games. I run a MacBook+4 Monitor setup usually but even with only one I get the same low performance (The same as my integrated 555x!) but I'm sure it's using the egpu as it even says it ingame. See this benchmark I ran yesterday for comparison:
Any idea why I might have this issue? Thanks in advance Smile
You're playing on a display connected to the eGPU? What display? Connection type?
Check the Thunderbolt link speed in System Information.app?
Show result from previous OS?
Clean install Catalina?
