Setup & Software Discussions
MacBook Pro 2016 model connectivity issue with Aorus Gaming Box RX580
(@kyung_min_ro)
I'm using the macbook pro 2016 model, with mojave 10.14.5
I connected Aorus gaming box RX580 model successfully.
There is no issue with working with egpu and it is possible to find from system setup.
But, I can't find the disconnect button from the top menu bar.
Is it possible to manually turn on and off the button? or any issue on settings?
Thank you.
Famed Member Admin
Can you check the full build number of 10.14.5? I recall certain version had a bug where the eGPU icon doesn't show up. You can either wait to upgrade to 10.14.6 or use beta 10.14.6 or even 10.15.
(@kyung_min_ro)
@itsage
Thank you for your information.
