MacBook Pro (Retina, 13-inch, Early 2015,) [2C, i7] + SAPPHIRE NITRO Radeon RX 5...
MacBook Pro (Retina, 13-inch, Early 2015,) [2C, i7] + SAPPHIRE NITRO Radeon RX 590 8GB GDDR5 @ 16Gbps-TB2>TB3 (Razer Core X) + MacOs 10.15.5
(@arturo_romboli)
Macbook Pro (Retina, 13-inch, Mid 2015)
MacOS Catalina V. 10.15.5.
Memory 8 GB 1867 MHz DDR3.
Razer Core X enclosure
(Apple) Thunderbolt 3 to Thunderbolt 2 Adapter
(Apple) Thunderbolt 2 Cable (2 meters)
SAPPHIRE NITRO+ Radeon RX 590 8GB GDDR5
I used Purge Wrangler to be able to install the eGPU using the Razer Core X. The patch installation went very well and the system identified the card right away, and it seems to somehow operate ok while it is not under heavy load. If I run Heaven benchmark (ultra) for example, or use Twinmotion (3D architecture platform / ultra settings) the system will freeze or restart after 10 o 15 seconds. The laptop will also crash if I want to restart it with the eGPU plugged in. I often gets the black screen w/ "Your computer restarted because of a problem. Press a key or wait a few seconds to continue in a few seconds" message.
I have researched a lot online and was not able to find a solution. I did come across a post in an Apple forum where the conclusion was that the Macbook Pro early 2015 is simply not compatible with the Rx 590 when using the Thunderbolt 3 to Thunderbolt 2 adapter. I am not 100% sure this is the case,
I would very much welcome any guidance or help to be able make it work. If indeed the card is not compatible then I will try to get a new one, such as the rx 580 or Vega 56
@itsage - do you mind taking a look at my setup/issue?
Macbook Pro (Retina, 13-inch, Mid 2015) running MacOS Catalina V. 10.15.5. Memory 8 GB 1867 MHz DDR3. Razer Core X enclosure. (Apple) Thunderbolt 3 to Thunderbolt 2 Adapter, (Apple) Thunderbolt 2 Cable (2 meters). SAPPHIRE NITRO+ Radeon RX 590 8GB GDDR5. iGPU: Intel Iris Graphics 6100 1536 MB.
2015 13" MacBook Pro [5th,2C,U] + RX 590 @ 16Gbps-TB2>TB3 (Razer Core X) + macOS 10.15.5 [build link]
